Fault Code 17705
Jun 23, 2011
627
Inverurie
Just unplug the MAF and go for a drive , if it pulls better then you need a new MAF if it is horrible and feels worse then it is likely to be something else, I am having issues with my LCR too and it is getting to be a real joke now seeing as I have only had it 2 months!
sounds to me like its the maf or boost leak.
Can you hear a hissing noise from anywhere in the engine (other than the turbo?). When I popped a hose I lost most of the power and could hear air escaping. If you can't hear any leaks, I'd look at the MAF. The N249 Bypass won't through that code up, that'll show a 17608 and another one I can't remember, but not the one you mention (they both relate to solenoid and open circuits. I.e the N249 solenoid) :)
Just also thought, as mentioned ooop there ^^^ could be a leaking DV, but you'd hear that hissing too I think
as said by russler i unplugged the MAF plug and wow what a power :lol: so im guessing its that as well as the low g/s im getting , instead of it being faulty may it need cleaned ? after fitting the jetex cone? , or should i just order a new one?
in reply to APE , nope no 'unusual' hissing noises , im guessing i would hear them from just revving it up with the bonnet open? , but i also didnt heard anything when i drove it, as well the n249 it did still have the chunky block in , but ive just put in the resistor that IE sell and its not throwing up any codes
cheers for all the help guys , pretty sure its the MAF , would haveing a faulty MAF decrease power? since im only seeing 190 bhp ? i know that when i did remove the plug it pulled so much nicer but would having a faulty one decrease bhp?
Jun 23, 2011
627
Inverurie
also on the subject , im getting sometimes peak boost at 19 psi? isnt this bad/ over boosting?? as car is standard i read somewhere it should be abut 15-16psi ??
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
a dead maf will cause boost leak error code (17705) the car doesnt know how much air is going in the engine, so fueling will be off also. power will be way down, boost wont be consistent. im 90% sure its the maf, buy a new one and buy oem (bosch) cheap ones dont work as i found out myself.
Jun 23, 2011
627
Inverurie
right will do , will get one straight from seat to be sure , when i get it all will let yas know how its going etc!
Jun 23, 2011
627
Inverurie
New MAF working a treat , thanks everyone for the input and help!
First Test Run after fitting saw peak g/s of 213 = 266 BHP ?? nuts considering cars not mapped
then after couple days did some BHP read-outs and was getting 255-258 so pretty chuffed still :)
Jun 23, 2011
627
Inverurie
Much better than my 202 g/s :( and mine's around Stage 2!
I think I have a dead / faulty / dirty MAF.
ooo , yeh must be something up , unless my car is mapped? (there a way to check this haha?)
better get it checked out :p , buy my calcs you should be near 230 g/s?
BEEFYGTI
625
Port talbot, south wales
I got the same error code. I have unclipped the maf but runs no differently. I have had a look for split pipes but cannot find any splits ? I have also replaced my forge 007p for the new forge dv. Any other suggestions ?
jimcupraturbo
54
I'm going to remove and clean my tb but some of you say is needs aligning how do you do that and what's it mean I've taken it off before and cleaned it but never had any problems before
Sent from my SM-N910F using Tapatalk
jimcupraturbo
54
I'm not have no means to check anything but I did clean the tb and now seems all good there was a bit of oil in there
