17's on an LCR?
Wolvo-Oleg
304
Wolves
As per title really..
I've been talked into going to a few of the shows at Santa Pod this season with a few of my old Ford Fwends, which is obviously gonna lead to a bit of 1/4 mile action.. I'm basically wondering if 17's will clear the front brakes, as I fancy getting some cheap used R888's or something for the strip..
I know you can get them in 18's but they seem much cheaper/easier to come across in 17's
Cheers in advance :)
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Factory fit options are
Code:
	Tyre		Rim		ET
225/45 R 17 91W 	7.1/2J x 17 	38
225/40 R 18 92Y 	7.1/2J x 18 	38
But I think you need the original Seat wheels.
Wolvo-Oleg
304
Wolves
Cheers lads. Are the optional 17s for the LCR? I just ask as I've only ever seen them on oem 18s.
To be honest, I reckon I'll see ky mates 180brake mk2 fiesta off on normal road tyres haha
maddox
263
Glasgow
I'd keep the standard wheels on mate. or stay 18. think 17 will make the car look out of proportion :shrug:
Wolvo-Oleg
304
Wolves
Cheers mate, would only be for the occasional run up the strip this summer, I'd keep the normal hoops on for daily duties
alias
317
Essex
They might. The 18" wheels which are standard on UK models were an option in Europe. European LCRs came with 17"s and I'm sure all LCRs came with Brembos. So if they had 17"s with Brembos over there then they should fit, although it is highly dependant on the wheel in question!
csd_19
2,280
28
Angus / Edinburgh
Wolvo-Oleg
304
Wolves
Cheers everyone, I'll put a wanted add up later for a couple of the above hoops :)
Or drop me a text if you've got a pair, 07772342596
Olie
May 13, 2007
1,017
Denmark
I have the 17" cupra r alloys as winter rims. Even the Brembo GT had not issues(a bit wider than the Seat Sport)
M206
37
hi, could you please post a pic of the brembo junior kit fitting on your arrasate 7,5x17 rims without spacers?
thanks.;)
May 13, 2007
1,017
Denmark
If you cant wait for the spacer picture... Then here a tasty-pic... :lol:
There is around 2-3 mm clearance, but space is space!...
So lets just slam that rumor about 17 inch wheels wont fit over Brembo GTs and 17 inch LCR alloys dont exist :eek:)
M206
37
GREAT!! Many many thanks my friend!!:funk::funk:
so i can go and order the brembo junior kit (not the GT in italy)!!:D
You confirm that you have the 323x28 discs??:)
and absolutely NO SPACERS??;)
M206
37
perfect!!;)
maybe did you measured the weight of one alloy too??
i forget to do that, and now my wheels are in the tyre-seller's store, at the moment i can't get them to test the weight..
i'd like to know the exact differecence of weight between the ronal arrasate 7,5x17 and 7,5x18..:)
May 13, 2007
1,017
Denmark
Id did not weigh the alloys, sorry. But the 17" are noticeable lighter on acceleration..
However, on winter tyres, at some point is does not matter as you want grip at "take off"... :eek:)
I could easily take the picture, but cant upload it before 22.00 tonight... hope that is fine.
