door seals
Trublu07
1,333
Essex
You mean the one where I am missing a grommet? I think the majority was from the foam as one corner has disappeared.
PAULTDI67
307
sheffield s.yorkshire
Hi peeps done my door seal but i'm still gettin wet in:shrug:used roor&gutter seal butyl rubber stuff(£4 from wilko's) it's not door seal as i've tested it wi hose(just does like it's meantto &pisses out drain holes on door bottom) also suspected dodgy bulkhead seem so i've sealed all welded seem&drownded it wi hose&dusted all footwell wi talk& no water traces:shrug: after few hours heavy rain i've got water on that black plstic sillsticker thingy but cant find where its gettin in:cry::confused:HELP i've also done this but it's still gettin wet:cry:http://http://www.seatcupra.net/forums/showthread.php?t=246917
cleverspoon
686
Iv repaired all my door seals abd still get water on the black plastic sill, the sill is on the outside side of the main door seal, i think it runs down from the top, around the door to there.
If your ancillary/ speaker carrier seal is still leaking then you will get water on the inside side of door seal, lift up where seal goes over plastic trim and mine used to be damp under there when they leaked, all bone dry now. However think my bulkhead or fuse cover under scuttle is still leaking.
PAULTDI67
307
Hi so if it's speaker seal why when i drownded door wi hose didn't it leak out o there?:confused: as i said just pissed out drain holes i sprayed door open&shut got in passenger side while my dad held hose on drivers door&couldn't see water coming in:shrug:
yea does leak from that fuse cover thingy where wiring goes to engine from fuse box check my link above or search in scuttle panel removal mine don't leak from there now:)
cleverspoon
686
I think water will sit on the plastic sill protecters, the lower ones, not the ones inside the car. If u imagine water comming from the roof, down between door and roof, the big main door seal stops it, so it will trace around the edges of that to the area your on about.
To solve it i cut v notches in the rubber seal on the very bottom of the door, inline with drain holes, this clears up the drain holes and lets water off sills :D
PAULTDI67
307
Hi done speaker seal thingy this wk while it's warm&sunny&dry also done that cuttin a bit o rubber 2 free drain holes:lol:(seems stupid idea 2 have rubber seal coverin drain holes)just got 2 wait till it pisses down next now:D(gotta b due been dry abot 4/5wk'snow)
Feb 26, 2009
5,275
Wolverhampton
There 'should' be holes in the rubber that line up with the holes in the door, although on my car they did overlap slightly so I only had half a hole.
PAULTDI67
307
Hi peeps WELL it's been pisin down 4 about a week now even had 2 days constant all day IT'S DRY!!:happy: sealed my speaker&while door card's off ran strip o silicone on door frame (where card fits upto):happy: ta guys y didn't i consider it coming from there!!
