Well my Leon is a 59 plate, so the early FL. I've just had a quick look on eBay. But not entirely sure what I'm looking for, any help would be brilliant.
anything on eBay under Vcds cable and cd should be fine, you can get some that are just the cable and you have to download the software from some dodgy site imo. You know now U think of it I might have 10.5.2!? Just to complicate things :)
actually I talk rubbish it wasn't eBay I got mine off and I can't be much help coz im on my phone, try searching google mate
Yea I'm on my phone too. Ive looked on google and found Ross-Tech but their quite expensive. And I found lots of OBDII but all website suggest to keep away from OBDII??
ok not 100% but pretty certain this is the one I bought, comes from china I think and you can't update it or it doesn't work but if you follow the instructions on the cd it works fine and can't argue with the price http://www.bestofferbuy.com/VAG-106...ce=gbase&utm_medium=cse&utm_campaign=gbase_uk
Hi there,
Just tried to activate staging on my MY12 2.0 TDi FR but it came up with ERROR: Channel not Available!!!
I've got a Genuine Ross-Tech Hex+CAN cable with the latest 11.11.4 (or what ever it is) VCDS.
Worked fine changing the coding to Rest of World so I could get the Digital speedo but doesn't seem to want to let me activate staging.
Module PN. is 1P0 920 950 N.
Can anyone else with VCDS thats done this check if they have a 950N Instrument cluster?
Or if anyone has any suggestions, I'm all ears
Paul :)
Further to the above, and after reading the Ross-Tech Wiki on Adaptations/coding.
Do I need to login through security access before trying to adjust the Adaptation values?
If so, is the login value of 13861 correct?
Paul
I didn't find the Needle Sweep feature in VCDS, and I have the 11.something one as well. Where can I find it, mate? I was able to change to Rest of the World and do a lot of other modifications but not this one.
Hi there,
If you go into 17 - Instruments then click on Adaptations.
Once it settles click on the drop down list ans Staging is there.
That's as far as I can get :(
Paul
