Noticed o/s/f tyre has a screw in it & n/s/f tyre has a nick in the side wall,lucky there getting low cos looks like new front tyres going on tomaro morning
Fittted my coilovers
[/IMG]
That looks sweet,can't wait to get my coilovers fitted :D
Back is as low as it will go,I have 10mm adjustment on the front.
A LCR splitter would last approx 10mins lol,actually I wouldnt get it off my drive
I'm sure you realise I was joking lol. What coilovers you using? I'm hoping Jom because I know they have one of the lowest drops and that's what I have got to fit on mine soon. Did you need different arb links to stop the drive shaft bottoming out? It does look awesome tho. It's lower than my m8s mk3 gti golf so he won't be happy if I go that low lol.
It's on jom mate, has the adjusters taken out at the back.. Needed a larger looped arb this is a must,my driveshaft and arb where touching. There isn't a lot of ground clearance lol.. I am running 225/35/18 tyres though,would rub on 40profile tyres I think
Removed all four wheelarch liners and cleaned the cack out from behind them ('04 Leon).
There were a few seedlings sprouting from the crud behind both front wheels! :D
Top tip: Check yours and clean them out before muck turns to rust....
Ahhh good to know. Well at least I know what I'll need. Fair play tho it does have a awesome stance. Didn't think the Leon could look that good :)
:redface: thanks.. I've spent a fair bit on it and put a lot of hard work in over the past two months so all the nice comments make it worth it.
Bought new coilovers :D
Sent from my GT-I9100 using Tapatalk 2
Chucked some Kumho Ecsta KU31s on the front. Much better than the crappy Triangle Talon sports they came with. There was nothing sporting about the old boots, apart from the tread pattern, recylcled plastic does not a good tyre make.
