Pop does your car feel like it's not driving right?
Sent from my Galaxy S3 using Tapatalk 2
Would like to help you but the leon cupras that i know of are in Denmark and owned by the local Revo tuner over there. Ig i get my hands on one i will log, promise .
Thanks POPOV, I'd appreciate that.
At the moment I seem to of hit a brick wall with it.
But are you thinking of changing your engine oil pan if you sort out the coding?
There's a member on leonIIPassion undertaking a retrofit of the TOG Sensor to a Facelift Cupra at the moment. It maybe worth a look for you!!!
SparK is his username.
Thanks for feedback. I will look into that later on when i have sorted my current issues ...
Anyone with knowledge in how the coolant temperature should be on the highway when just cruising?
Mine is about 81C and when i get in to town it goes to 79C when driving. When i stop the coolant temp will go up to 90 + and the fans will start as they should.
I need to confirm that the coolant temp should stay at 90C when driving normally. According to what i read on some forums it should always be 90C and if not the car will automatically push in more fuel and cause the rich status i have.
on normal driving your car should be on 90 degrees , never seen mine go over that even when giving it some beans![]()
