bbd ch size on lcr
james291
93
inverness, scotland
What size bbs ch do people have on there lcr i bought a set of 18x9j et35 and they fit perfect on the back but the front need 10mm spacers and then they stick out the arches by atleast a inch just want to see what size i can change my fronts for so they dont poke out by miles, thanks
Harris.
355
Essex Bruv
Guys a friend at work has just bought ch reps 18x8 et35 and they don't for over the calipers. Will need a 10mm spacer then they stick out way too much. What offset does he need on the front?
Brettyboy
2,597
Exeter,Devon
I don't think 5 mm will be enough to clear the caliper tho. Strange.
Its is !
Surely if you had ET30 8.5j with 5mm spacer that is the same a ET35 with 10mm spacer but you have an extra 1/2" on the rim that would surely poke out more than 8J
Harris.
355
Essex Bruv
Trust me mate they will need more than 5 mm spacers. All I can think off is that they are reps l, but then surely et and width is the same no matter what wheel.
