yeah mate it should work with any kind of turbo :)
I'll post up my latest code with the oil temp and boost in a bit
just pull the clocks out and ease the clips out so you can pull the front off them.
i trimmed the hole a little bigger to fit the 16x2 display with a stanley knife and under that i had to hack away quite a lot of white plastic to fit my lcd into it.
This is whats under the plastic front:
No where near big enough by Muzza1742, on Flickr
and this is what was left of it once i'd finished
Much more room by Muzza1742, on Flickr
and the fitted lcd:
Test fit by Muzza1742, on Flickr
you could easily cut down on the hacking if you changed the lcd to a normal hd4770 one instead of the serial unit i used.
Its held in place just by pushing the front back onto it
sorry mate i just aint got the time at the min, sorting out my bumpers and doing the decorating in the house is taking most of my spare time.
if you want a professional version i would check out zada-tech. they aint cheap but you would get proper support if anything went wrong and finished code (mines still a bit work in progress and ive still got to integrate the ODB2 adaptor)
if you mean the whole plastic front then its only held on by 6-8 clips. just need to lift the tabs and it pulls off and pushes back on again
Looking good Muzza, ive been tempted to purchase the parts as the fitting I can do, just the electronics Im not too good at lol..
I just keep on reading different pages on the net about it, then its, do I or dont I.
Firstly, apologies in advance for bumping a 2+ year old thread. :whistle:
Secondly, is there anyone on here that could build and fit one of these to my LCR? :confused:
