Hey guys,
My car developed a loss of boost at higher rpms (and therefore pressures) on Friday. I think (I've not checked) it either has a non-OEM diverter valve or a spacer on a standard OEM one, either way it vents whilst I'm still on the gas at higher revs - its therefore broken.
Needing a new diverter valve I've looked into this very same issue today. I think the G type is the old revision of the previous diaphragm part:
http://www.audizine.com/forum/showthread.php/257963-New-OEM-DV-06H-145-710-D-Diaphragm-Removed!
http://www.my-gti.com/476/volkswagen-oem-diverter-valve-upgrade
I'm going to buy a replacement "D" type - 06H145710D.
There's that much on this valve on this forum and other VAG forums I think I've confused myself but if my two penneth helps......
I'll let you know how it goes.
Kev - where did you order yours from?
Cheers,
Joe
