Cool an off-road Leon
Looks good though
well after re fitting a new thermostat about to weeks ago(the seal was leaking abit)so changed the stat as i was there also changed the coolant temp sender AGAIN..................????(tempture guage taken about 20mins or longer to move)when i brought the car there was a recipet shown for a new one replaced about just over 2 months agowas it replaced or just a cheapo one no idea but temp guage now working fully
its kind of a good thing when you have small issues in the engine bay because then at least you get to know your self around the engine bay.
many many ppl might know this but for others they might know and can help them.....
if the temp guage takes ages and wont reach to normaly working temp (before 90dgs or even close)and then goes up and down (mainly down)then ur sender is gone(orange light might come on also)
the thermostat in the block only lets in cooled down water from the rad and had no signial to the guages.
Funny you should mention this as I have finally just got round to replacing the thermostat earlier on my Leon 1.6, since having the waterpump done a few weeks ago the temp gauge has stopped working again (it started going funny weeks ago and I replaced the CTS sensor which cured it for a while).
After replacing the stat and enduring the entire coolant tank emptying itself and then putting everything back together, I filled up with new coolant and started the engine with the cap off and let it run for a few mins with the heater fans on cold... but the gauge still did not move?? After about 15 minutes I noticed the coolant level in the tank kept fluctuating and farting as it should with air escaping but then I noticed that the coolant level rised right up near towards the tank filler!
I then turned the engine immediately and then level went right down to the min mark, so then I topped it up again and then let it run again for a few minutes before deciding to put the cap on and go for a 6 mile drive... and the gauge still did not move at all and it only moved slightly when I pulled up back home! After reading up a few threads on here I proceeded to squeeze all of the pipes just to make sure there are no air locks anywhere.
Was it normal for the coolant level to rise worryingly right up to near the tank filler? Does it sound like something still isn't right if the gauge isn't working as it should?
Thanks - Liam
It can also be the stat under these circumstances
Took delivery of new pagid disc and pads.
Good choice sir![]()
