just read another post you have alread changed teh DV.
PCV Valve?
not had the pcv done but it was mentioned when booking in for diagnostics.
Unfortunaly never made it there with the bloody clutch slip.
I m going to midland vw to hae the clutch and fly wheel done £740!!
Then i will book back in for diagnostics!
I've had the unrated rev d DV changed and the PVC still not make any difference I'm changing the alternator next as the cam belt with rollers etc and the aux belt,tensioner, DV and induction kit replaced, only thing not changed is the rear PVC check valve which is probably going to be next on the shopping list lol
Sent from my iPad using Tapatalk HD
Crigisback - did you ever get this problem sorted? Got the same problem on my Leon Cupra 2008. :(
Unfortunately not mate. I had it looked at but it needed to go on the rolling road to be diagnosed and the clutch started slipping so could not do it.
Since sold the car so I will never know?!!!
Although the guys I spoke to said it sounded like a pulley squeal under load
