Get it on the rollers!
Wouldnt you just beable to tell if its mapped from attactching a boost gauge? If its running more psi than standard then its been mapped.....?
Yes, get some logs done, and I'll tell you
it's not 100% effective way of finding out and others but boot it down a slip road through gears 3 - 6 and have a look whats coming out the back!!! on mine Pre-map the smoke was barely noticable and after theres a bit of black soot kicked out especially in 5th! (it's also Revo map too not a dodgy one so the black smoke will be there if it's been done )
Ok, whats required and what info do you need specifically?
Thanks.
As above, log channels 8 and 11 at wide open throttle in 3rd or 4th.
is that how you get requested and actual boost figures?
could you explain how to do logs please? its about time i used vag com properly.
Yes, this will give actual versus specified figures.
http://www.ross-tech.com/vag-com/tour/logging.html
also have a look int this thread http://www.seatcupra.net/forums/forumdisplay.php?f=104
that reminds me why ive never done it its not very clear to me just a load of numbrers and mental instructions.
