Fixed rear washer fluid leak and fitted my Badger 5 TIP :) Still needs a wash though once I have located and fixed a coolent leak at radiator.
My new handle and mech I got today
Note for LEE69, I checked it against the part number on that parts website and comes back that the colour is Persia black lol
Check my original post, it says testdrive vid right under the pictures. No error codes whatsoever (yet) :) Made a testdrive and drove it hard, very happy with it.
You'll eventually get a code for an N249 fault, purely because the ECU can't open the HKS like it can with the normal DVs to regulate boost etc ;)
I still swap about between my Hyperboost DV and my REAL :p HKS SSQV from time to time :D
Took it to Badger 5 to have smoking exhaust lpoked at, seems as though my pcv non return valve was broken in half and was leaking. Bill fixed that and had a look around and did some logs. All fine now and was happy with the dyno run results . Felt a lot smoother and quicker on the drive home. :)
