Got a link handy for the bsh intake?
Thanks mate =]
they only make them for the petrol tfsi but i would buy one and make it fit
you mayb beter off with the neuspeed less messing and the same effect same noise aswell
Thanks mate =]
Finally got S.hark map, running a little bit smokier than usual as its more power =]
However a day after the remap, i got a engine management light =/
So i got the VCDs on it and the error code was:
012593 - EGR System
P3131 - 006 - Regulation Range not Reached - Intermittent
Anyone have any ideas?
The car still runs perfectly well, with no more judder either =]
Just a little bit annoying that the engine management light is on =[
Let me know
its the map it has failed to remove the egr so the egr delete is throwing up a code
***** need to fix ther remap
and you should not hav to pay a penny for any of ther soloutions as its should of been done properly when they did the car
contact them again and complain
i agree with Jamie
The EGR delete hasn't been mapped out correctly... there's 2 way's of mapping out a EGR Delete they got mine wrong first time aswell
now happy wit hanother tunner making 25bhp more thru all the rev range and an extra 50ft of torq now at 400ft torq and 263bhp![]()
btw the ***** map is no slouch at the top end its just down a little in the low and mid range
spinning my wheels at 60mph in 3rd is fun now![]()
ok here is my new mapping
my 5ark map made more bhp at the top end BUT it was lacking power on the botom end and midrange
if you look you can see i am making around 25bhp more thru the range apart from the peak at the top end
resson for loss of power at the top is we hav reduced fueling by about 15% over the 5ark map and also reduced the amount of duration
5ark map was making my EGTS very hot 1000c in 3rd gear massive overfueling and causing the excess fuel to burn in the exhaust manifold
i dont think 5ark are talking to me any more as i have changed tuner and then i got removed on facebook ??? LOL
im just not a patiant person and im not wating months and months for a company to decide they can do my car how i want it doin
i could also gain teh power back at the top if we incresed fuel and duration a tad more also ther is more to come as im aiming for 2bar of boost atm it is around 1.9bar ..
in these test you can see the ***** map made more bhp but would it be the faster car on the road ? less power and torq thru the midrange
YOU DECIDE
also the ***** run was made in the morning after a slow drive to rstuning after a full day on the dyno around 20 runs we then got the rstuning results
and to say its only 3bhp down over the ***** map and was probably heat soked to hell i think it has done prity well
i also think ther is a tad more to be gained from the ecu adaption not much but i think this new map will be on par with the 5arks map's MAX BHP
im happy rstuning is happy- 5ark probably not that happy as they dont hav a hybrided pd170 to test on anymore![]()
Does anyone know if FL headlights fit a NON FL Seat Leon FR with btcc kit?
