Dec 29, 2010
1,103
Mids
I'm looking into wheel spacers at the moment want some 15mm for the rears on my LCR just noticed they have hubcentric with longer bolts, and then bolt on hubcentric spacers ??? At least with the bolt on hubcentric you use your old bolts and locking wheel bolts..... Anyone experienced these bolt on types......
I'm very interested in going this way
Im using bolt through. I prefer it tbh! The bolt on ones are easy to strip threads. Especially at 15mm!
so lemme get this right, there are a set that bolt onto the the hub then you bolt the wheels to the spacers and there are sets that just bolt through both the wheel and the spacer onto the hub??
Correct !! It's so you use your original bolts if you used the bolt through type then i don't think you would get locking wheel nuts that long
Also Anything under 15mm on the bolt on type and you need shortened
Now that's a good point
Ah! Got it :) so if i wanted to get a flush look what sort of size would i be looking for without rolling the arches??
Think most people go 15 front 20 rears but I was looking at mine today and I'm happy with the fronts how they sit but the rears are well in the arches so I'm going for 15mm bolt on for the rears only at 1st
Sorry Damian I'd already ordered fk 15mm bolt on type before you replied I did send you a email few months before though but didn't have a reply, I'm NOT HAPPY anyhows the spacers was delivered to find when I put them up to the rims my studs bolt through into the spacer and around 3mm of thread was sticking out, so I was then told to cut down my original bolts which I'm not doing as when i ordered them i was told they would be a straight bolt on no issues so sent them back to swop with 20mm .....ill see how they look might just sell them and swop tyres to 235's
Ill see how it looks with the 20mm before I decide to keep and post pics.... I wanted 15mm because I didn't wanna touch the fronts but now think 20 rears and standard fronts will look soft.....
I went 12mm front and 15mm rear both bolt through type
Rear
Front
Overall
Hmmm looks like your email didn't come through.
Yes that's why we only sell bolt through 15mm spacers.
Damian @ DPM Performance
