you lost your fogs?
Thinking of using the space made on the passenger side where SMIC was to mount an oil cooler instead though
Cheers mate, still needs fettling to be just right.Top work Tim, looking good.
Its been my plan to run welded FMIC piping in this route with oil cooler in the freed space for about 2 years now and only justgetting round to it nowMy oil coolers going in the driver side. Fogs are for gays any way. Looking good.
Cheers dudeTop work mate, looks really good
The car did look properly gash without a bumper but im sure it went quickerLeave the fogs out, every bit of air flow helps![]()
A bubble test? not heard of doing this? i assume it is a leak detecting device as per gas appliancesdo a bubble test....... then you will want to remove it and revert to oe
I was quite happy with the 007 i've had on for years but since i had the bailey one lying around i thought i'd put it on just to see what it was likeGet a collins dv same as a dv30 but sound loads better had one on my astra gsi best dv in my opinion
Sent from my ST25i using Tapatalk 2
How are you finding the FMIC? didn't you say at Blyton that you were 1gs away from hitting limp mode? Take it you've had no issues? Have you got a date in mind for starting the 4WD conversion?
