stoy2die4
Hey guys,
I have the Cupra style Orion wheels on my Leon that go stock with 225/40-18. Any of you running 235 or 245 on /40-18? The reason I'm asking is because I want a bit of a softer ride and more wide look. Going on 225/45-18 is absolutely out of question..
. That's why I will go with a wider tire which will bump up the height too. I will go under the car tomorrow to check if the rim is 7.5J or 8J to make sure I can do that operation..
Any suggestions?
. That's why I will go with a wider tire which will bump up the height too. I will go under the car tomorrow to check if the rim is 7.5J or 8J to make sure I can do that operation..Any suggestions?
