jamescupra1
201
Hi I have a 2003 Ibiza tdi and my turbo Makes a siren noise I'm thinking of repairing it myself never done it before but il give it a go. Does anyone have a guide on how to remove the pd 130 asz turbo and what would my turbo code be, I've been told gt1749v and then another site says k39? Any help would be highly appreciated and merry Christmas to all :D
The Seat PD130 isn't the Garrett 1749 turbo, it's the cheaper variant.
DIY turbo repair isn't as easy as you think as you're dealing with fine measurements to ensure it stays together and it doesn't rattle itself to death.
It should be a KKK KP39, however, a PD130 turbo from other VAG models of similar year (except Passat) should fit, not 100% but I'm sure someone else will confirm...
not always the KKK turbo, the KKK was introduced on the facelifts along with the BLT engine block, the pre-facelifted cars mainly came with the Garrat setups which prove to be more realiable than the chocolate KKK's.
There are exceptions to this but that above is the general rule of thumb
I haven't had time to remove turbo but I have managed to get the make and model it's a kkk k39 0012 I need a guide guys can somone help?
I managed to remove my turbo today it was alot easier than I first had thought. I taken it out thru the top wich was the hardest part. My manifold and egr was rammed with old tacky oil and had to be cleaned. Upon inspection of my turbo there seems to be no play in the shaft and not impact of the impellers to the side wall of the turbo I had only done 2 miles max when I heard the noise so I guess I was lucky to just get away with the bearing damage. I'm goin to attempt the pull apart and service of the turbo next week, its an upgraded part with a 360 bearing. Just for further reference what ft lbs do the manifolds have to be when I refit them? Thanks
Well badger u where right turbo repair isn't easy lol turns out bent shaft and mangled impeller
I'm lookin for a new turbo do I think the arl pd 150 1 will fit? I heard its a much stronger unit
Not sure about the PD150 as the manifolds may be different, the more knowledgeable will confirm if it does.
However, I quick search on Turbo Dynamics Website appears to show the a PD130 Turbo from the following models are pretty much a straight swap;
Audi A3 1.9 TDi 130BHP engine ASZ engine code, year 2001 to 2004, OEM No 038253016F / 03P253016Q
Seat Alhambra 1.9 TDi 130 BHP ASZ engine code, year 2003 onwards, OEM number 03G253016Q
Seat Cordoba 1.9 TDi 130 BHP, year 2003 onwards, OEM No 03G253016Q
Seat Ibiza 1.9 TDi 130 BHP, year 2002 onwards, OEM No 03G253016Q
Seat Leon 1.9 TDi 130 BHP, year 2003 onwards, OEM No 03G253016Q
Seat Toledo 1.9 TDi 130 BHP, year 2003 onwards, OEM No 03G253016Q
Skoda Fabia 1.9 TDi 130 BHP ASZ engine code, year 2003 onwards, OEM No 03G253016Q
Volkswagen Bora 1.9 TDi 130 BHP ASZ engine code, year 2001 to 2004, OEM No 03G253016Q
Volkswagen Golf 1.9 TDi 130 BHP, year 2001 to 2004, OEM No 03G253016Q
Volkswagen Sharan 1.9 TDi 130 BHP, year 2003 onwards, OEM No 03G253016Q
Ford Galaxy 1.9 TDi 130 BHP ASZ engine code, year 2002 onwards, OEM No 038253016F
I don't know exactly how reliable this is but if it's a ASZ engine, you should be fine.
Pd150 unit fits, you'll have to bypass the egr and clock it compressor side but it'll go on as a straight swap.
Hi guys do u think this turbo wil fit my car?
2001 SEAT LEON - ASV
1.9 TDI (110 BHP)
**GARRETT TURBO / TURBOCHARGER**
GT1749V / 094038253019N
