I like those Ronal's. Do it.
K-Sport's will be good!
Richard (mechanic) is back on 3rd so will see what he thinks & we'll get the software on, as getting major chatter from turbo at the moment as revo 2 clearly doesn't know what to do with all the new mods.
Scan with Vagcom to confirm that the chatter your getting is not a missfire. Revo is fine with the hybrid other than running rich which you can tame by making adjustments with unisettings. Search on vwvortex with regards to the limitations of the manifold you have fitted.![]()
Sorry mate, the same thing happened to me, but its not appropriate to post some things on the forum and you can be seen as a hater etc. But all well that ends well and do consider a V3 xs mani as it will work well out of the box.One word...bollocks...I tried to find info on these manifolds but to no avail, it was the cast option that appealed but looking at the timing of the posts on vwvortex is the same time I bought mine so not surprised no info. Thanks though at least there is a solution. Having done all the work myself I'm quite prepared to hack away at the collector
Sorry mate, the same thing happened to me, but its not appropriate to post some things on the forum and you can be seen as a hater etc. But all well that ends well and do consider a V3 xs mani as it will work well out of the box.![]()
Yep.Will vagcom on sat morning. Stupidly I left all my tools at the garage over christmas so can't even change the spring till sat when I go down there.
So yours was the LCR referred to on that thread. Thinking that I might just cut losses and ball ache and get the relentless v3. Am I right in thinking that they have delevoped for ko4 hybrid and the GT eliminator?
Good times ahead.I put the car on vag com this morning which after clearing all the fault codes (11 of them) we put revo 3 on. Took it for a spin and opened her up. The chatter or flutter is still there but only when lifting off throttle, & even under very light load it does this?? But my god does she fly. However when on full wot at about 6500rpm engine light came on and it juddered. Checked for faults and multiple cylinder miss fire and cylinder 2 miss fire, plus n249 intermittent mechanical failure (this valve is deleted) Cleared them and did gradual run & no faults, then again on wot and same faults at the same rpm. Diagnosis on miss fire is definitely the mani. Not sure on the flutter yet or why the n249 is only throwing a code when miss fire occurs on wot.
Current settings are fuel 6 & boost 6.
Any thoughts on the flutter & n249 fault code?
Whilst some grumbles to iron out i'm really pleased so far![]()
Hi James, thanks for the well wishes, this is our 2nd & last! Good luck with your impending arrival. I will definitely aim to come over to the uk next year, i've given the mod bug to my sister & she is desperate for me to come over. She's got a mk v r32, I'm a little jealous to be honest as I nearly traded in for one last year but it had already sold, that's when I decided to go all out on the LCRHopefully Chris. Mine should be about ready by then to travel about to shows and meets, so would be good to meet you and see your car, which is turning out to be a very nice build. Any further thoughts on what wheels/brake set-up you'll be going for?
Enjoy the arrival of the new baby; our's arrives in 7 weeks or so. Super excited but terrified!!!
James![]()
