Wet Wet Wet!
Up until only this week, my LCR has been dry since I've had it (4yrs), but I noticed a small pool of water in the front offside footwell. Car was parked facing downhill for a couple of days.
I dried it out using a VAX, and then parked it uphill, only to discover the next day that the rear offside footwell was now soaked.
Lifted the carpet and again sucked out the water (about 1 litre).
Following day with car still facing uphill, the front footwell was wet again and the water had run back to the rear footwell.
This time, I noticed under the tray above the foot pedals, it was very wet when I rubbed my hand over the plastic. So water could be coming from the engine bulkhead.
Spoke with
dealer, and they suggest they have the car for a week, whilst they take out the enire carpet to dry it, and replace all door seals (v common
problem) and check other seals. They would then do a water test to check for leaks, before putting the carpet back.
Total cost £570
Might have to bite the bullet, as this will only get worse....
