Hi guys,
I have a problem with my 2005 Leon FR TDI 150, it has quite a few miles on the clock.
Since I have had it in November it has had difficulty engaging 1st and Reverse, it does eventually engage after a few tries.
I have recently been tracing a boost leak issue, but now I believe I have a different problem; when on partial throttle, between Idle and 2000 RPM, I get a metallic screeching noise when accelerating, this tends to usually go away after 2500 RPM. Also occurs when lifting off the throttle completely. It is a high pitched noise that sounds like a very loud whistle but not a traditional boost leak noise.
Also when engaging/disengaging gears especially from cold I get a thump/judder I can feel through the clutch pedal over the last few weeks.
Does this sound like classic DMF/Thrust bearing symptoms?
If so I am in the market for a mid range clutch/DMF flywheel combo.
I want to keep the dual mass flywheel as I didn't like the vibration I got from my previous leon tdi with the SMF, ideally need it to handle 300ft/lbs torque as I plan eventually to get a remap.
Budget is sub £550 if possible any suggestions would be appreciated.
Thanks in advance,
Dominic
Thanks in advance,
Dominic
