Id want 50-60mm drop, and improved comfort. over anything else.
Coded the rns510 for optical parking system and it works a a treat![]()
If you have an rns 510 satnav or maybe non sat nav version (big display) and vagcom you should ba able to do it, you have to go onto radio and theres an option for optical parking system display then go to park/steer assist and enable optical park assist under rear camera (you may have to unlock the security if it wont let you code it) job done![]()
If I'm reading this right then. Have you installed a reversing camera?
sorry no i meant the option is underneath the reversing camera option on the first byte/bit
