00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LK HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9249
Revision: --H05--- Serial number: SEZ7Z0F3626032
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 73EE68A612AE09B
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004737
Shop #: WSC 06441 785 00200
3 Faults Found
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
00283 - ABS Wheel Speed Sensor; Front Left (G47)
So I just about got home by driving really slow and got VAGCOM onto it, this is what came up for the reason of ABS light coming up. Codes cannot be cleared as they just come back up. Now would this be the cause for the Traction and tyre pressure light to come on aswell?
Can this easily be fixed and where are these located? This was all caused by the snow and build up in the arches.
Still need to find out why my brake pedal goes to the floor to apply pressure
Any advice on this?
Coding: 0050071
Revision: 00H11001
Coding: 0004737
3 Faults Found
Any advice on this?
