Masterkm
My Leon 'Alyssa'
Jul 11, 2011
2,700
Halesowen, West Mids
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LK HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9249
Revision: --H05--- Serial number: SEZ7Z0F3626032
Coding: 0050071
Shop #: WSC 66565 257 00032
VCID: 73EE68A612AE09B
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004737
Shop #: WSC 06441 785 00200
3 Faults Found
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
003 - Mechanical Failure - Intermittent
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
00283 - ABS Wheel Speed Sensor; Front Left (G47)
So I just about got home by driving really slow and got VAGCOM onto it, this is what came up for the reason of ABS light coming up. Codes cannot be cleared as they just come back up. Now would this be the cause for the Traction and tyre pressure light to come on aswell?
Can this easily be fixed and where are these located? This was all caused by the snow and build up in the arches.
Still need to find out why my brake pedal goes to the floor to apply pressure :(
Any advice on this?
Sounds a bit odd that you have 3 sensors gone down at once. Jack up each wheel and check it on vag com in measuring blocks for abs and manually spin each wheel up to check the sensors. Sensors are a piece of piss to change just wheel off most sensors are on top of the hub 1 bolts bit of wd40 and a wiggle and its out!
Thats what Im thinking its odd, going to leave it parked till the weekend now. Will take each one off and clean them to see if that helps and reset with VAGCOM.
This should hopefully turn off all the lights then right? If these lights are on, do the ESP button and Tyre Pressure button still work or not? As mine dont.
The g201 code is if the pressure sensor has failed.
I maybe totally wrong but I'd say either abs control unit or the wiring is damaged.
Could the control unit plug have water in?
Personally I think I'd disconnect one sensor and see if vcds knows its unplugged or if the code stays the same.
The control unit plug is at the abs unit behind the battery on the passenger side against the bulkhead.
Definitely worth unplugging a sensor to see if the code changes to open circuit.
Strange why they all say mechanical failure!
The big connector? My mate took that off and put it back on after work, didnt look like water was on there. It does say intermittent too so that shows a little hope.
Would these have an effect on the 2 buttons ESP and tyre pressure?
ESP and tyre pressure warning won't work with a abs error as both are done through the control unit which needs wheel speed.
Just searched the net it seems people usually just delete the codes and others have required a new abs ecu.
I couldn't fully understand but somebody mentions all the abs speed sensor wires run through a connection under the bonnet.
If that's true that's where your problem will be.
Worth a look.
My ABS pump went on the car in June last year. Fortunately i had warranty on the car and it was sorted. They do a repair kit or the unit now instead of replacing it in it's entireity which is cheaper.
looking at what is says ie mechanical failure that normaly looks to be the sensor reading the reader ring on the wheel beatings if the sensor or wiring fails it normaly comes up with electrical failure .try cleaning sensor and the area where the sensor reads off
That's what I would normally say but to have 3 at the same time is strange.
That's why I've asked to unplug one to see if the code changes.
Well, I went out to the car this morning to move it to a safe parking place and there was no light on the dash, maybe thats because I only moved about 50ft and the sensors didnt go off. So temporarily the lights are off atm. Looks like a clean up job. Yesterday whenever I put the key in the light stayed on even after I did VAGCOM so something has changed today :S
Having the same issue but only on front right. Trying a clean up of the sensor and ring this weekend, looks like an easy DIY. Fingers crossed that sorts it.
Any joy with this? My front rights showing problems, replaced sensor, no joy, where does the cable run once it goes into engine bay?
I had to change hub and sensor and mine was sorted, the rear passenger has started to play up a lil and shows up as electrical fault so guessing is the sensor this time round for sure. But its intermittent so due to weather i cba dealing with it atm
Yeah, started at the front drivers and found a big gap in the sensor ring on the hub. Changed the hub and all back to normal.
