Tim,
Just a quicky, think i've asked you before. Have you bolted your battery box down or welded it? I'm thinking of just spot welding / tacking it to the floor rather than drilling holes through the floor! Don't really fancy a boot with a load of holes in it.
You really should try and make it secure as possible, if it breaks loose it will fly around the inside of your car like a 15kg sledge hammer
If you go to most industrial tool suppliers they should sell them, just ask for roofing bolts
They dont require a nut, they have a hexagonal head then a thread and the tip look like a drill bit and come in various sizes and lengths
If you are locating like mine there is a head shield over the backbox so the underside should get too coated in crap
You will however need to drill a hole in the boot floor to make a new earth
Good progress lads!Not really had much chance to use it fully, however the gear based part of the map has come in handy when swift pulling out manouvres, etc so you dont sit there just making noise and smokeLucky sod! I can't wait to get mapped it seems like one step closer and three steps back at the minute. How are you getting on with the map and gear based boost?
YEAAAAAHHHHH RANDOM DESTRUCTION!!! AWWWWWWEEEEESSSSSOOOOOMMMMMEEEE![]()
This makes me smile, inside and outGood progress lads!
You should come over sometime mate, hopefully the weather should be getting better soon and we can all stand around in oily clothes drinking tea with engine parts all over the place
Getting dangerously close to the big 30Always a interesting question but how old is getting older?![]()
May be getting older but still not getting any taller!![]()
