leon cupra r brembos on ibiza
Willow86
I've got the same problem there is a bloke on eBay that sells the smaller carrier to fit the Ibiza Cupra r discs but they are for a Porsche caliper but can't give me a straight answer, I've had a look at cutting them down myself but you ain't got anything to drill the new holes in
neron4o
24
Sofia, Bulgaria
Sorry for using your thread....
I'm running icR with Brebmo brakes,std 305mm discs x 28mm min thikcness, I want to put 323mm x 28 mm from lcr,but I remember Bill( badger 5)said, the dics are diff offsets. I cant find his post,so may question is theres some way to make those lcr discs fit??? I am with 17"rims- 15mm spacers in front.:whistle:
turboholic
CupraPower
Mar 4, 2010
355
Bristol/Bath/Frome
You will need 9mm spacer between the caliper and carrier to fit the disc in diameter wise. Then you will need the carrier machined down for the offset of the lcr disc. Then depending on the et of your wheels you may need spacers
Sent from my GT-I9305 using Tapatalk 2
