Got back from shark after an eventful day, Left the house at 6:45, drove about 10 mins down the road and the car went into limp mode not good with a 2hr journey.
Eventually got to shark around 9 not bad considering i had no power what so ever.
1st they put the sportlines on and had massive trouble getting my wheels off as they had bonded with the hubs, these have made so much difference to the handling!
Front
Back
Then they carried out a baseline rr run without the dpf and obviously no longer in limp mode, the car made 195 bhp, ben realised the car had already been mapped and not very well (explains why it juddered and span up so much) after putting it back to standard it ran 173 bhp and 387 nm torque.
Then they started to map it the car made 202 bhp and 429 nm torque on stage 1
Then ben started on stage 2 as i am using their sts sytem so i can switch between stage 0,1 & 2 which made 218 bhp and 455 nm torque and is so smokey, it actually filled the whole of their
workshop with black smoke, ben was saying when the injector recall was carried out they don't set them up properly so once i get them set up the smoke should nearly disappear.
The rear end this moring, think i will be running stage 1 every day now
A photo doesn't show how dirty it is, i will do a 50/50 shot when i clean it next
On the drive home the A1 was shut from Grantham so the diversion went up to melton mowbray then back to stamford which added another hour onto the journey home so ended up getting home at 10:15.
Really pleased with the results and has completely transformed the car over night.
