What did you and your MK2 do today?
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
537
Halifax
Got this on Friday...
...And fitted it today. Had to go spend £30 at Halfrauds so I had the right sockets - stoopid VAG cars. Took her out on a private road and there is a difference, although my damn tyres are rubbing under hard cornering. Also, I went over a speed bump and heard a slight 'clunk' from the rear - I've put it down to having a thicker and stiffer bar, anyone else heard the same thing with this on?
I'm also getting very peeved at my gears 'sticking'. The car doesn't come out of gear as easily as it should and it needs a second bite of the cherry to get it out and into the higher/lower gear. Could this be an alignment issue or something more serious...?
Benjic2
1,029
Its hard to see from the pictures but are there locks either side of the bushes, to stop the bar sliding through it? The clunk is the bar sliding through the bushes/mounts. If not, you need a lateral lock kit. I went for the whiteline ARB because they were included with the bar but you can buy them on their own, ableit expensive! See below :)
http://www.youtube.com/watch?v=PtYMmsizaec
http://www.jbsautodesigns.co.uk/product/4146/
Mar 12, 2012
537
Halifax
It has the locks mate. Drove it this morning and the clunks and creeks are worse... :cry:
Mar 12, 2012
537
Halifax
Strange, did you put plenty grease on the bushes? The only other thing it could be are the droplinks :confused:
Yep, put tons of silicone grease on.
I was wondering about the droplinks - is it possible to overtighten them? Surely they aren't broken after 20k - although stranger things have happened.... :shrug:
Mar 12, 2012
537
Halifax
Slight update. Just spoken with Ed at APS and we reckon i've done my usual trick of overtightening the 'D' bracket that holds the bushes. Ed reckons this will stop the bar from rotating as it should and putting pressure on the droplinks which is causing the 'clunk'.
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
Drove it to work for the first time since picking it up on Saturday, got to be honest and say I don't think I've ever been so eager to come to work lol :funk:
miss_cupraR
lovin' the leon
Jan 24, 2009
178
Lurgan
well it wasnt today.... got these done a few weeks back- black skirts and triple r splitter .... the skirts arent to everyone tastes ( im still undecided!) lol
CJcupra
233
Surrey
I'm feeling those skirts. From the pics it doesn't look to 'In your face'. :clap:
Where did you get them from?
CJ
nerayan
Nerayan
Apr 8, 2010
717
Portsmouth
Personally I think the way the splitter gloss black colour continues into the side skirt,then tapers off is absolutely brilliant. It mates it more balanced
Jimbobcook
6,175
2,560
I like it! Keep them I say :D
Sent from my HTC One X using Tapatalk 2
calvR
392
Kent
Had a minor service at Amd essex. Whilst it was being done I walked over the seat dealer to look at a mk3. Only had a basic model in but looked good on the inside trim wise. The outside however, im not convinced, the rear door handles look awful, looks like they forgot about them, then realised at the last minite n threw one in the middle of the door
Benjic2
1,029
I really like that. I can see this setting a new trend.
Same mate, the interior is much much better but the outside is absolutely horrific, it's completely boring, even on the FR models. I'm hoping they do a better job on the cupra but I have my doubts... all will happen is the usual nostrils in the bumper and behind the reg plate sprayed black :rolleyes: I think the R will be quite different though, but its probably a few years away?
