Going by their website there is no dealer in Scotland. I have asked in the email but awaiting a response.
If I sent it to them though would it just be a case of them removing the limit which cause the limp mode.
Sean's Xperia arc
yes or drop the boost load request down to where its actually able to produce.
either works, both work... and yes that would fix your limp mode
Is asking for 1 bar boost at 6k+ rpm normal on a 'k03s'?
I'd have thought that jabba would have their maps perfect... They've been doing this for a while!!!
Sent from my iPad Mini using Tapatalk HD
the usual max a healthy std actuator k03s will hold in my experience is 12psi (1827mb in map sensor terms) Asking for more than it can achieve is'nt the issue, most maps ask for all thats available its just the deviation map has'nt been adjusted to accommodate any shortfall or overshoot.
Thanks for the answer.
I plan on bringing my car the 5-6 hour journey down to you, hopefully this year if all works out well, and have you custom map it for my k03 053 set up I will be running by then...i may go on to hybrid it if funds allow before mapping. I hope it makes the grade for ALS, gear based boost, NLS set up you offer.
I want it done right and it seems there aren't many options for that, when even the 'reputable' company's put out bodge jobs when they should really be doing a lot better!
I know what u mean tucker. It's annoying when the reputable companies make basic little mistakes like this. Now means im going to be without the car for a week to get it fixed. Wish I had gone to bill last year.
Bill ps I will most likely be ordering elliptically grooved 305 discs and fredo ds2500 pads next month.just a heads up :)
Sean's Xperia arc
