chichee
84
Broxbourne
Am I right in thinking that the front brakes (caliper, carrier, discs and pads) from a Skoda Octavia VRS is a straight swap onto a SEAT Leon TDi 130?
From reading it looks to be the same set up as the 312mm on the TDi FR.
Tdi fr has 288mm discs!
Octavia vrs is 312mm front and 256mm vented rear!
What size discs do you use as you'll probably only need the carrier as the caliper is the same on the 288/312
Lol...I've got it all wrong!
I've got 288mm front discs, so, as you said, I only need the carriers for the 312mm discs and the larger discs?
Yeah calipers are the same on the 288/312's
All you need is the 312 carriers / new discs / new pads and your rocking
