James D1
Pre-facelift
Aug 2, 2012
253
Essex, Uk
just want to share my experience with changing the dogbone mount and a few tips and tricks we used.
first we got the car on axle stands
then undone 4 retaining bolts holding the dogbone onto the car, 2 on the head and 2 on a trailing arm.
from here we went inside (it was cold haha)
this is where it becomes very fustrating and turns into a pig of a job.
how to remove bushes using normal home tools, although id definatley advise an extractor as it will probably do the job for you.
to undo the retaining bolt compressing the bushes, i stood on the dogbone whilst my stepdad used a ratchet to undo it (unless your one strong cookie i advise someone stand on it)
when thats removed you can split the head from the shaft (no inuendo's please) and remove the bushes, if they were standard there most likely half melted so you need to scrape all the gunk out.
now comes the real pain: removing the lower bush!!
we tried various methods, from sheer stupidity to sheer brutality, but a method that finally worked is one id advise you all to do
we used a 29mm hole saw (drill attachment) this seemed to fit perfectly over metal centre and took the rubber out. you will have excess rubber in there but nothing a a knife wont remove.
now you have a nylon sheef to remove (it looks like part of the mount but it needs to come out) we hacksawed a little nick out then hit it with a screwdriver which popped it straight out.
we then opened the 2 packs containing my polybushes, we started with the pain (lower bush). we lubed the hole with copper grease and used 2 bits of mdf (anything thin will do) and pressed the bush in using a vice. you really will need a vice or a press for this otherwise its nion impossible.
to fit the rear trailing arm onto top of the lower bush we filed the hole out a little bit as it's hexagonal hole.
fitting the 2 top bushes is easy as they only go in one way. although it gets tough to refit the retaining bolt and other obscure method was used. you have a fiddly little nut to manouvre under the shaft in order to fit the bolt. because new bushes are firm and tougher material you will have a hard time refitting the bolt. we moved the nut until we got the bolt in the hole and then my stepdad put his weight on the top whilst i tightened the bolt (it finally bit after 2/3 mins of messing about)
finally a complete upgraded dogbone mount. this job is not a 5 minute job (as some suggest) it took us a good 2.5 / 3 hours with no specialist tools or knowledge.
fitting it back onto the car is very simple, 4 bolts and bang! job done.
(i will try and get some pictures uploaded so you can see what im rambling on about) hopefully this helps someone out.
heres 2 pics:
these are the 4 bolts holding it onto the car
lower bush is shown on left of image, thats where we used the holesaw. too the right is the retaining bolt
I did it the easy way as my standard dogbone was knackered! I bought a 2nd hand one and gave it to the fitters at my work and let them get on with it!
The bolts had sheared on my standard mount so knew id have to smash it to get it off
And the finished product with a2 stainless bolts fitted (no more corrosion)
nice to see other people's methods. hopefully this will help others who find themself stuck when trying to do this upgrade.
as for giving it to the fitters, that would be nice haha, i could have taken mine into work where more appropriate tools were but i needed it done that day as i had to take mum,sis and fiance shopping. yay
What size bolt was it?
M8 bolt (i think) may have been an m6
Think i put 40mm ones in
Sorry to bump this, can I get some more accurate details on the bolt? I fancy getting myself the bush but don't fancy running into trouble with the bolts
It won't be m6 that's far too small my slef I'd say by the looks on the pics it's about a 13mm bolt head size so if that's correct I'd say its 95% Likly to be m8 in size if its a 14mm to 17mm head size of bolt then I'd say 95% Likly it's a m10 bolt size so in other word just get a a spanner on the bolt see what size spanner head it is then look at the above and walla u know ur bolt size hope this helps
you shouldnt run into any problems with them, well mine were fine anyways. nice and easy does the trick.
and remember theres always time for lubrication!
thought they were stretch bolts?
They are!
Almost every bolt on vw is!
I've changed my whole suspension
Dropped the subframe
Uprated dogbone mount
And used all the original bolts! Not lost any yet!
Tights tight and too tight is f*****
