Thanks Tim![]()
As tim said
Thanks mate and good luck makes the bay look very empty
Thanks Tim![]()
Not really had many of these during my ownership but I'm getting niggly problems and one possible big one that are dampening my mood with the leon
Things I've gotta do
Brakes (next week)
Cambelt
Door seals poss as front window steaming up while driving.
Now the problem
Code 16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded
Boom and there is it!
Pickup pipe is being fitted next week to try cure this if it doesn't it will be going for a oil pump pressure test
Failing that its vvt at a lot of money so need to decide whether to go that bit extra and rod my spare engine, or take vvt out of spare and fit to mine, buy new from dealer or call it a day?!
You should know by know its never an easy ride with these cars! At least you have plenty spares around!
It was already like that richy I brought it off someone so don't know if he did but doesn't look like it.
It's have the front bumper done and the sills as bits have chipped so hopefully be back good as new ready for some maintenance
Next on the list service with pickup pipe, rocker gasket and cam gasket (timmmmmmmmm!!!!!) rear brakes then fronts, Tim's poly wishbones then arbs and map! Long list but I aim to get stage 2 before summer ends!
