Had another play with some headlights, just need to polish up the lens and then they will be on eBay unless I get an offer here!
*Pictures*
Hey robthebubble,
Do you still have these for sale or have they been sold?
If you still have them how much would you want for them I can't find them on eBay.
Is that a question to me? If so they are pre FL, they are bi-xenon which is connected to the existing full beam headlight giving you dual beam. However, this is only if you are going down the HID route....if you were to stay with standard halogen bulbs its a case of changing the wiring so that they act as both dipped and full beam. The existing side lights would still be used too.
Basically, unless the ballasts are fully charged the bi-xenons won't flash hence having the original full beam lights, however when your dipped beam is on the bi-xenon works (as the ballasts are already charged).
im thick as foook when comes to things like this i can do things with my hands but trying to understand thing involving electrics fry my brain lol
i have the standard headlights so would i need to buy ballasts like as if going hid then these will just plug straight in yeah??
Got the car terra cleaned to try and get rid of the misfire. It didn't work :(
The mpg got better but that's about it unfortunately.
How much is the terra cleaning stuff? Also where did you go big eck?
Gutted you've still got that misfire :(
Its £126 all in mate. Warpspeed performance in Kilbirnie do it.
Sorry to hear it didn't clear up the misfire problem Eck. Remind me, have you changed the injector in the problem cylinder yet?
That's the next thing to be done now mate, its quite a big expensive job so I wanted to try the cheaper most obvious things first. I think the injectors around the £100 mark but its the labour to remove/refit the inlet that's gonna cost me.
*Pictures*
Hey robthebubble,
Not on eBay yet as I still need to do the other headlight! Lol they will be for sale and I've had some interest in them already. As for a price, I need to work that out based on a set of OEM headlights, the bixenon projectors, shrouds, XB led halos and my time to make them! Will keep people posted once done however I will be making some more if required!
You don't need HIDs with ballasts although these headlights will work and pass the MOT as they don't dazzle oncoming drivers. You can use standard H1 bulbs however some minor connection alterations would be required but this can easily be done to make them plug n play!
thats good then as dont want hids as mot testers get iffy and i just have bright white standard bulbs. when you have prices set up let me know asap as love them
Had 2 new back tyres and alignment done as my back tyres had done the 50p shape on the inside rim...
Sent from my iPad using Tapatalk HD
The only reason the MOT tester is a bit iffy is because people put them in their standard reflectors and they are so bright they dazzle oncoming drivers. Hids is bixenon projectors have the correct cutoff line just like OEM bixenon headlights. You can buy Hids with the H7R bulb which basically has part of it covered and helps to stop dazzling.
Once sorted ill let you know. Remember, these lights are bespoke and can be designed to different styles based on the shrouds, halos etc.
Not massive but noticeable so far. Usually around 25mpg about town, its just over 30mpg now.
5mpg increase around town is a good improvement. my mpg came up 5 mpg after having the timing reset.
Could you have a loom problem instread of the injector itself. What about doing the labour yourself to save costs.
This guy is in Ballymena but he is an injector specialist in that he refurbishes them and sets pop pressures etc. You could maybe see if he could advise or help in some way.
Details are :- Tommy Wright 02825639400
That's even closer lol. Nice place dollar. Take a trip into Stirling for a bit of shopping or go visit the castle. Wallace monument is a must to go visit as well, some of the best views in the world from the top. The climb up the spiral stair case is dizzying as well lol.
I used to come up your way a lot got friends in Lanarkshire well its 4am and I'm leaving for Scotland
Sent from my GT-I9505 using Tapatalk 2
Okay cheers, just keep us posted please.
