Change the map??? Or tweak the map? Can this be done with stage 2 revo ?
yes it says if you have a stage 2 revo map that will work fine.
Q: What about software?
Quote, originally posted by »
You can run a tweaked k03s file, REVO stg2, GIAC k04-001 SW, APR k04 file, or Uni stg2+ (i'm not sure if there's a eurodyne specific file).
Hmmmmm , may have to look into that myself .
That's the one!!! Go for it if you want it to break , then the internals fall into your engine...... Bend your rods, knacker everything else in .
Stay away bud.
Sent from my iPhone using Tapatalk - now Free
Save the bit extra bud. We all want one yesterday sort of thing. Trust me ...... When these engines brake , they brake properly!! Last thing you want is that turbo failing and crumbling into your engine. My old ko3s did that ( was turbo from factory ) , and needed new engine . Shot oil out exhaust , so also needed to buy new cat. Bent all the rods and snapped cam shaft also. Big Bang!!
