I have a new SEAT Leon with the technology pack which includes the Media System Plus / Navi System and wondered if anyone else has had the following problem with a USB memory stick plugged into the MEDIA-IN multimedia cable:
The system will play my MP3 music tracks correctly from the USB memory stick, but sometimes after switching off the system and then switching back on later, the system doesn't recognise that anything is plugged into the multimedia cable. The only way to make the system see the USB memory stick again, is to unplug it and then plug it in again while the system is switched on. I have tried several USB memory sticks and they all do the same thing. I have also checked the cable, plug and socket and there are no loose or intermittent connections. I also put exactly the same MP3 tracks onto an SD card plugged into the SD2 socket and that is always recognised, so I wondered if this might be a software bug. I think the problem usually occurs if the last display before switching off was the satnav, but I need to check this again to be sure.
