Cheers Will, don't think I can be bothered with the retrofit in the existing lights. My days if tinkering to that level are over thanks to a wife three kids two dogs and a hectic job lol.
Plus no where to put car whilst I do it as my garage is now a gym, the lenses are on the limit of recovery too I reckon at least two hours a side to refinish.
Thanks again for all the tips.
Ps one. Ore I promise. I assume the leads just plug into the existing leads off the headlight to the ballasts etx and then back into the headlight to the bulb. Did you run this via a gap in the housing/cover or drill a hole?.
Dependant on heat I was planning on adding thick rubber draft tape to allow te cables to pass through whilst retaining a seal. Or does the slim ballast fit into the back of the headlight.
I guess there may be hear issues with that tho?.
