Good morning,
This is quite a long post but I am trying to give as much info as possible so that people can help me.
Bit of background -
I have a 115,000 AMK Cupra R with a silicon TIP and open cone filter, mpg and performance seems to have dropped off recently, although it may have been like this since I have owned the car, I can confirm that the MPG has got worse but that maybe my driving style as I get used to the car, tick over has definitely got a bit more lumpy.
I have replaced the spark plugs to NGK Platinum, had the cambelt, water pump and oil changed with 5/40 synthetic.
I have taken off and checked all pipes including the ones under the inlet manifold and replaced the one that was perished/ split and so I am reasonably confident all is well with these.
Tickover can be bit lumpy sometimes but it starts well and runs well, I have a boost gauge fitted and it climbs to 12 psi and then holds around 10psi under WOT and shows -25 on tickover - assuming the gauge is reasonable accurate but it does hold boost.
Engine sounds nice and quiet even from cold and there is no smoke from the exhaust even after being driven hard on engine over run etc so I think Turbo seals are OK.
After reading many threads on this forum I have spent sometime this morning running a series of tests to hope that someone can give me some advice as it is clear that my power is well down.
The conditions for the test were 2 degrees outside and the same piece of road each time which is uphill and carried out in 3rd gear.
There are 3 tests with a combination of measuring blocks - please have a look and if anybody could give me some clues what to do as I am unsure of what to check next - the only point I would make is that stationary at 3,000 revs measuring block 003 tells me my maf reading is around 10.5 which I believe is a high ?
Anyway here are the logs -
Whilst I know a far bit about the mechanics side of things I am now at a loss where to look next so I would really appreciate some advice from people that are far more clued up than I am
Thanks for looking
Bit of background -
Thanks for looking
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
