Guys,
Can anyone supply a picture and/or part number of the OEM gearbox mount bush that is commonly replaced by a poly bush to reduce wheel hop (such as the powerflex item below.
Thanks,
Horace
Horace this bush does not replace an OEM part, it complements it.
Seems that way.
So to take it back to OEM, just remove that poly bush, and the washes.
Tell you what, why not bump a few more threads and see if you get an answer![]()
Just fitted some BSH mounts, Gearbox, Lower mount plus Engine Mount.
Vibrates like crazy. will it go away ? I am thinking on changing the Engine mount back to the stock mount and keep the gearbox and torque mounts BSH, what do you guys think ?
Car: Seat Leon FR 2.0TFSI 2008
The vibration will lessen as you put a few miles on and break them in. I would stay as is if going big power
ok great. because i feel like im driving a truck, hearing all kinds of sounds.
how much % less vibrations will there be after some miles would you say ?
I am even hearing sounds from the clutch when the car is in neutral. But when i press the clutch in, the knocking sound goes away. (I thought it was the gearbox mount at first)
Im thinking its the slave master cylinder, or maybe i need to change my timing belt kit which i have not yet, and the car has just reached about 100.000 km
