More progress made today...
			Fantastic work and attention to detail as always mate. Wish I had your patience for these things! Glad you got the subframe off ok, looks like a good finish. How hard is it to roll the arch lips? I'm worried about catching the fronts when I get my new spacers on.
Was also underwhelmed compared to the first UD I went to, agree on the nu-wave comment but most of inside is just company demo stuff now.
			Looking good James.
I agree about ultimate dubs. I did like the white Cupra R inside tho.
			Cracking work as always mate
Thanks chaps
So, I had another productive day on the car today. First off, I reassembled the refurbished subframe, wishbones, dogbone mount (I refurbed that 3 yrs ago!!!), and R32 FARB. Really pleased with how robust the stonechip is.
I then started the task of stripping down the arches by removing all the plastics, steam cleaning away all the dirt with a hand-held steam cleaner that I purchased for the house
 Once cleaned, I masked up the areas and stonechipped, top-coated and lacquered them. Pretty chuffed with the results with no sign of any overspray (smiles)
Being impressed with how robust the stonechip was, I decided to cover the lower plastics, which attach to the floor; finished off with topcoat and lacquer. Really pleased, so I think I’m going to do the arch liners too. The idea behind is that they should hopefully weather well and be easier to clean.
I then wire brushed and painted the hubs with Hammerite and then reassembled all the bits. Remaining to fit is the subframe and arch liners, which will be done first thing once I have rolled the arch lips. Then its BRAKE FITTING TIME
 Might be able to bleed the brakes tomorrow if time permits then that'll be project done
On a side note, I went to do the well talked about gearbox mod, but it seems I have a different casing
 I'll save the parts until the gearbox gets an LSD in the years ahead.
