Is an engine swap out of the question? Legally or money wise? I dont know much about Ibizas diesel engines but wasn't there a 2.0tdi? Buy a used full engine and tranny and swap it in as a whole package? Of course that only works if they share the same wirings, mounting points etc. That would cost much but you would get much more headroom and still have the reliability of a stock or almost stock engine.Well thats sounds right![]()
In my case Id have to spend 35,,000 pounds to get a car with the same horsepower![]()
I have to do some math
Well in colder weather it accelerates really well, its brutal in 1-2-3 gear, well not compared to a cupra i guess.. but for my standards it is..
You can make a burner in 2nd gear.
Based on that statement my first mod would be the bigger intercooler to maintain what power you have.
A bigger turbo will generate even more heat.
The universal intercooler some are fitting is around £120 in parts.
Can you get a larger intercooler, that fits the car as it is mate?
I did read itI got off where it said id have to cut the grill to fit it.. im not a tech nerd for thus kinda stuff..
i make Koni shocks lol
Sounds fair.. will i gain power from a intercooler?
I was wondering, the remap of 140 bhp. Is that the maximum of the current turbos potential? Or could they make a custom remap to increase power without changing turbo?![]()
Me said:Other providers will come up with more power and torque than APEC Belgium / Revotechnik: We are definitely in favor of competition in the market, this can only benefit the consumer, provided sufficient caution! Why "only" 130/135Pk? The 1.6TDI with smaller intercooler + aspiration (Audi A1, VW Polo, Seat Ibiza, ...) we + - 130HP The cars with larger intercooler aspiration (Audi A3, VW Golf, Seat Leon, ...) we + - 135HP When many tests (6 months development ability banking and public road) has shown that an excessive amount of fuel results in a high inlet and exhaust temperature, both are crucial to the reliability indicate. In itself it is very easy to 150 + HP from the 1.6TDI pick, but in that case the exhaust gas temperature limiter to an extent to be written that the reliability SERIOUS jeopardized in the short term, this should not be a problem, However, in the medium term this will result in faulty turbos, leaky gaskets (head plate gasket), particulate filter problems, melted pistons, ... Concrete APEC Belgium / Revotechnik maintain their position that +-140HP (dependent on the measured exhaust gas temperature under cycle load (dyno)) the absolute maximum for the reliability of the engine and drivetrain guarantee. Also let the speed limiter, writing / increasing this limit allows the exhaust and oil temperature under heavy load (speed) to such an extent that increase engine damage (immediate) is very real. With this the view of the first and as yet only tuner (APEC Belgium collaboration Revotechnik) worldwide who 1.6TDI of tuning can provide. High capital gains as a marketing stunt by us does not arise! Regards, The APEC Belgium and Revotechnik team
If you are happy about the power at cold days but loose power at warm days you have to fit the intercooler. The cold air intake wont do a thing on a normal car like yours. Manufacturers usually put the intakes quite nicely and in most cases stock one is better than aftermarket. Those who say that they made power with one do have placebo effect because of the sounds and that people say that they make a difference. Its always act of balancing between good filtration, high airflow and coldest available intake air.I will fit a larger intercooler, also maybe do a cup air intake
Then we will see about the turbo
