Well thats sounds right :)
In my case Id have to spend 35,,000 pounds to get a car with the same horsepower :)
I have to do some math
Is an engine swap out of the question? Legally or money wise? I dont know much about Ibizas diesel engines but wasn't there a 2.0tdi? Buy a used full engine and tranny and swap it in as a whole package? Of course that only works if they share the same wirings, mounting points etc. That would cost much but you would get much more headroom and still have the reliability of a stock or almost stock engine.
The turbo swap is not out of question as it is the easiest way to get the power you want, but only if you are ready to upgrade things that will brake when they can't cope with the power or the torque.
Yeah it would be too big project for me mate :) i thought about it, but the costs would be huge :)
What kinda things would brake cause of the torque?
Clutch, gearing etc? :)
I am sure I read somewhere that the remaps are rained in to around 140bhp because the con rods are not very strong and they end up bending at higher powers. It is an economy engine after all. Would love to know more on your build though if you do find tuning parts. Good going getting that torque though your car must fly!
Well in colder weather it accelerates really well, its brutal in 1-2-3 gear, well not compared to a cupra i guess.. but for my standards it is.. :)
You can make a burner in 2nd gear.
im really thinking about the turbo.. i will be willing to change some parts to make it last, but not to the extreme :) budget is wih a newborn baby so..... :)
Based on that statement my first mod would be the bigger intercooler to maintain what power you have.
A bigger turbo will generate even more heat.
The universal intercooler some are fitting is around £120 in parts.
Can you get a larger intercooler, that fits the car as it is mate?
Or you would have to mould the car to make space? :)
would air intakes make an effect worth noticing?
I did read it :) I got off where it said id have to cut the grill to fit it.. im not a tech nerd for thus kinda stuff..
i make Koni shocks lol
I was trying to suggest that having an intercooler fitted will be far cheaper and less hassle than having a large turbo fitted that will need a custom map to run it and possibly larger injectors to supply enough fuel.
Sounds fair.. will i gain power from a intercooler?
I got a good prize for the turbo and custom remap.. not for injectors
I was wondering, the remap of 140 bhp. Is that the maximum of the current turbos potential? Or could they make a custom remap to increase power without changing turbo? :)
No, thats the max of the engine. the rods aren't heavy duty enough to sustain much above that safely.
The 140 is pushing the heat limit of the engine when fitted ot the smaller cars as it is.
yep.
Me said:
Other providers will come up with more power and torque than APEC Belgium / Revotechnik: We are definitely in favor of competition in the market, this can only benefit the consumer, provided sufficient caution! Why "only" 130/135Pk? The 1.6TDI with smaller intercooler + aspiration (Audi A1, VW Polo, Seat Ibiza, ...) we + - 130HP The cars with larger intercooler aspiration (Audi A3, VW Golf, Seat Leon, ...) we + - 135HP When many tests (6 months development ability banking and public road) has shown that an excessive amount of fuel results in a high inlet and exhaust temperature, both are crucial to the reliability indicate. In itself it is very easy to 150 + HP from the 1.6TDI pick, but in that case the exhaust gas temperature limiter to an extent to be written that the reliability SERIOUS jeopardized in the short term, this should not be a problem, However, in the medium term this will result in faulty turbos, leaky gaskets (head plate gasket), particulate filter problems, melted pistons, ... Concrete APEC Belgium / Revotechnik maintain their position that +-140HP (dependent on the measured exhaust gas temperature under cycle load (dyno)) the absolute maximum for the reliability of the engine and drivetrain guarantee. Also let the speed limiter, writing / increasing this limit allows the exhaust and oil temperature under heavy load (speed) to such an extent that increase engine damage (immediate) is very real. With this the view of the first and as yet only tuner (APEC Belgium collaboration Revotechnik) worldwide who 1.6TDI of tuning can provide. High capital gains as a marketing stunt by us does not arise! Regards, The APEC Belgium and Revotechnik team
I will fit a larger intercooler, also maybe do a cup air intake :)
Then we will see about the turbo
If you are happy about the power at cold days but loose power at warm days you have to fit the intercooler. The cold air intake wont do a thing on a normal car like yours. Manufacturers usually put the intakes quite nicely and in most cases stock one is better than aftermarket. Those who say that they made power with one do have placebo effect because of the sounds and that people say that they make a difference. Its always act of balancing between good filtration, high airflow and coldest available intake air.
Fit the intercooler and at least you would be making the 140hp all the time and you wont loose that much power when driving hard for long periods.
Today is 24 degrees celcius, I just drove a trip of 20 minutes, with around 65-70 mph, around 110 i think..
The heat problem seems to be intense, i mean, even with the standard 95 bhp. It would do this?
I have in no way pushed the engine, so im thinking the intercooler might be too small even for the standard ecu?
I could feel the heat when i popped the hood..
