jase20vt
185
bloxwich walsall
I know this would have been asked before but after quick search I didn't get definite answer.
So how do actually sort this problem?
Do I need vag.com or can I do it with key?
I've bought another mk1 fr recently and the remote central locking only worked on one door. I reset it by disconnecting the red lead to the car battery for like 10 minutes. Worked for me, but I wasn't changing the remote battery at the time. If you try it, make sure you know your radio code, I didn't lol, fiancé not happy
Reactions: jase20vt
Ah then what you need to do is a bit more complicated..
Open your window
Open drivers door
Loosen, don't remove, torx screw in drivers door releasing barrel
Remove barrel and shut the door
Use a flat head screwdriver in the slot where the barrel was to operate what Key A should. But using key A in ignition and pressing buttons through the window.
Be careful not to hold the screwdriver in position too long or it will shut the window!
I had the same problem with my 02 cupra it seems the code reader becomes number dyslexic when the batt is removed so I had it re programmed key and reader
Open your window
Open drivers door
Err that sounds rather nasty...
this will be sorted soon.
I have a friend who owns locksmith company, iv not spoke to him in a while so didn't want to ask for a favour. However he called me during the week for a chat and it came down that he needed some welding doing on his 1972 beetle. new rear valence and couple of other panels fitting. For this he is going to sort me a new key and recode both of them :)
