Ah then what you need to do is a bit more complicated..
Open your window
Open drivers door
Loosen, don't remove, torx screw in drivers door releasing barrel
Remove barrel and shut the door
Use a flat head screwdriver in the slot where the barrel was to operate what Key A should. But using key A in ignition and pressing buttons through the window.
Be careful not to hold the screwdriver in position too long or it will shut the window!
