@Pher is it possible to have the modify.Exe with the Cupra with 5doors instead of 3doors cause my Ibiza have 5 doors and on the PID the seat only show 3 doors since i put the modifiy .exe.
Regards
I think Seat Cupra with 5 doors doesn't exist, so i think is not possible to change that.
Best Regards
Does anyone know how to get this to work with the latest Garmin firmware (7.14.11)?
When I copy this file over the top and start the device I get a blank message box with OK and cancel buttons. OK does nothing and cancel reboots the device?
This file doesn't work with the new version. I need to make a new one but at the moment i'm very busy and i do not know when i will have some time to do that.
@Pher thanks hope you can do it soon as i want to have this change 7.14.11 :
- Bug fixes in the BT functionality
- Support of DAB radios
- Adding additional radio logos
- Bug fixes in the support of the electric variant
- Live menu can also be selected during navigation
@Pher have you had time to watch the new file ? Have lot of BT issue and i would like to install the new version but i love the Performance display too much
Id say go for it. It really helps with connection issues. Performance display you can always update later. Of course it's easy for me to say but I'd say the biggest missing thing would be engine temperature gauge. And if you have a couple dollars you can buy a BT OBD reader with a smartphone or tablet and get all the same data plus million more different things that you could use until someone makes new files to SPS.
Sent from my HTC One_M8
For the record, the new update has engine temp as one of the display options anyway, the only thing missing is boost and the performance tools, but I found I rarely used them anyway. Can't knock the new update, it's a big improvement over the previous version
What else is in the new update?
Hi there
I'm having a problem with my Seat Portable System. After I connected to PC with Navigon fresh a few times, now my device doesn't boot, I mean, it stuck in a black screen with 3 lines ( B: 2.50, OS: 2.21 e BT: H144...R39) and it's a kind a boot loop, those lines appear, disappear one second, and then appears but nothing happens. Can someone please explain what's going on? I didn't make a backup before that :(
I have a Seat Ibiza 6J 1.2 TSI FR 105 hp from this month, August...
Can someone give some clues? some help?
P.S. Sorry about something about my English :)
Try to hold the power button down longer. Like half a minute or something. Don't remember exact time but it should do a full reset of the device if I remember correctly.
Hi guys. I have a Navigon PID and a Ibiza 1.2 style slasa. I am working hard on getting my Navigon to work on my car. My current process is this:
*device boots normally
*When you click on the Car button it shows bordcomputer and performance display. Both are greyed out. If I turn my ignition on the performance becomes clickable. But if i click it says some like: not possible on this version...
My final thought we Navigon users need to get the vwusershell submitted bei pher to work. The depencies it's using are the same. Maybe someone has an Idea..
Gesendet von meinem LG-D802
Make sure it is clipped into the dashboard correctly, that'll make the gauges grey out
Wont help as Navigon didnt get the performance gauges if I have understood correctly.
For testing purposes I have an win ce 6 emulator running on my pc. Any idea how I can pull the Navigon .dlls from my device?
Stuff like Rom extractor or active sync dont work unfortunately.
Currently i am trying to do it via mscr script
We are all waiting @Pher to make the modification in the new file to update our navigon :)
Please Pher! I know you can do it! Greetings from Mexico City!:clap:
