Auto Adjusting Wing Mirror
askew
26
Once you hit 15mph and the central locking kicks in it'll revert to its original position.
Seastormer
Cupra Leon VZ2 300/CBF1000
Apr 25, 2014
5,402
898
69
Edinburgh (Scotland)
Sorry, I should have added at the end, the mirror does stay down until I put the selector knob back into the centre position.
I did expect the mirror to return once I drove forward but I suppose that would mean the mirror constantly going up and down if you needed to shuffle back and forwards while parking.
So to recap, as you did above but don't re-adjust your mirror at the end, simply put the knob in the "0" position rather than the "L" position.
You can leave it in L or 0 after setting it up, I did it with the engine still on when I first set mine up. Engine still on, put into reverse, set LH mirror to the position you want to see the kerb, put into drive and drive off, and the mirror went back to normal position. stop car , the LH mirror is still set to L, put into reverse and it dips to what I set. I then put it to 0 so it only dips when I choose, not wanting it dipping for every reverse, just when parking next to kerb.:D
askew
26
Yeah, after I adjusted it this morning and started driving away I was all "Ah FFS - now it's stuck looking at the floor". Until I got out the car park!
MarkBeatty72
88
Blyth, Northumberland
Possibly a blonde moment, but I have no option in the mirror/wipers setting for this. Should they be one?
All I have is synch adjustment, fold in when parked and auto wipers which are all ticked.
Wonder if this build has the missing or faulty reverse mirror setting
VIN number is VSSZZZ5FZER028974
Rob2k68
122
Rugby
Mine was also disabled by Seat - it would be useful to know what the part numbers are and cost to correct this.
In the meantime I've enabled it using VCDS and find it 90% functional and still well worth having only needing to manually correct it every tenth time or so. Also enabled it on my neighbours Octavia VRS works perfectly on that.
scrich7
311
Bedford
I'm in the same boat - no option to enable as my car was in scenario 2.
Might have to get round to getting a VCDS cable and doing it that way.
Would also be interested in understanding the costs of rectifying too!
Rob2k68
122
Rugby
I need to get to my Seat dealers find a 14 plate car with this working and give the parts dept the reg number. If I use my reg they'll prob supply the exact parts with the issue !!
I'm up for doing this removing the door card is pretty straight forward then i'd imagine it's disconnecting the harness removing a couple of bolts and changing the mirror glass and cap over.
TheJudge09
Well, tried everything suggested but in the end had to admit defeat and go back to the dealer and as some suggested earlier, there was a production issue a while ago and the feature was deleted.
Guessing my car was produced during that period.
Looking at the YouTube vids of it in action tho, it doesn't look like it moves a great deal anyway, so will continue with having the mirrors synched and doing it via the button if needed.
Rob2k68
122
Rugby
Ok so now contacted 2 Seat part departments and have been told the same - the mirror on my car is identical part number and revision to a late 14 plate car reg that I gave to them although they won't give out part numbers !!. The mirror is £83.83 which I thought was reasonable and the glass £53.57 which is less so.
So now back to square one, the issue must lie elsewhere which leads me to the control module. Can anyone with a late 14 plate car, working mirror dip and access to VCDS post the Central electrics module details please. Mine are :-
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011317400069
Coding: 0B000B46C24102FB0BA44000B11C0728102A000000000000000000000000
Shop #: WSC 00049 770 00244
ASAM Dataset: EV_BCMCONTI 011001
ROD: EV_BCMBOSCH_SE37.rod
VCID: 77FB9BB7CE3EAEA6AAD-8022
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119
Component: WWS370 130604 041 0574
Serial number: 130606163946
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M06D25H09M40S07S4
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY131001RT9
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000057164951
Rob2k68
122
Rugby
This one would also be useful :-
Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000064871726
Coding: 00100220D001020000001000
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 010FF56F90FAE016949-8054
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Component: FOND_FHSG_PSG 005 0004
Serial number: 00000000000000288112
Coding: 350000
Rob2k68
122
Rugby
Just spoke to parts department and have a number and price of the passenger door module having given them a number plate of a recent 14MY car :-
5Q4 959 592 BZ00 £94.37
Still can't verify if this is the part needed to fix this on early 13MY cars without removing my door casing to see what is fitted to mine.
Rob2k68
122
Rugby
It may be parts that are required, I'm not sure would prob have to be whole unit including motor etc.
Hi, thanks for that - I had read that before and that was my understanding but now 2 parts departments have told me that my mirror part number is the same as that fitted to current cars so I'm now looking into the door module. I'll phone up tomorrow and see if I can get the number of the module fitted to my car and if different I'll buy the later one. It doesn't bother me too much I'm an automotive design engineer by trade and very inquisitive ;o)
