Triple R FR Custom Rear Diffuser
Jarre
5,365
11
Stockton-On-Tees
is it the whole rear valance or just the diffuser that bolts straight on?
The whole diffuser, sits over your standard one. So basically remove the number plate and remove the screws underneath the diffuser. Place triple r diffuser over the top and replace screws and put number plate back on
Nov 27, 2011
640
the Wirral
when you get it fitted mate, and your in liverpool any chance i could see it?
CJcupra
233
Surrey
Couldn't wait any longer for the diffuser so decided to get the valance sprayed gloss black. I actually prefer it like this tbh. Would be good to see pics when they're are fitted though.
CJcupra
233
Surrey
Jarre
5,365
11
Stockton-On-Tees
Apparently working on it but it's not as simple as changing it slightly, it'll be a whole new design I imagine.
They said they need a rear bumper so they can start designing.
locky
1,073
North East
So easy that anyone walking past with a screwdriver could remove it for you too?
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
How is it attached/held on at the top? Get some pics when fitting :thumbup:
m.001
149
I assumed that as well. I was sure it would be a replacement for the valance you already have on.
Screwing it on to the current one seems really odd tbh.
Jarre
5,365
11
Stockton-On-Tees
As I said above, held on by the screws underneath and your screws in your number plate (so you may wish to get bigger ones?).
To make it a replacement would probably require a lot more design work as they'd need all the clips as well to secure the edges. By doing this design it's only a few screws I guess.
m.001
149
that makes me a little uneasy. A screw on piece for the whole rear valance doesn't seem to secure.
Jarre
5,365
11
Stockton-On-Tees
Your entire car is held together by screws!
Hubbly's diffuser is like the cupra r one in that you cut down your original diffuser and only the bottom half is new, top half is the original.
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
I read what you wrote, the reason i asked is simply because my numberplate doesnt sit at the top of the original panel, so having a panel simply sat over the top held onf by 2 numberplate screws which are half way down will mean the top section is completely unsecured.
