Yeah, less than 30p of it. He's still turning a profit
Either way still better than nothing.
Back to the gearbox oil I used Millers Oils TRX Semi-synthetic 75w-90.
Should be fine if it meets the VW spec, though I use a fully synthetic Fuchs Titan FE 75W which was advised by Opie
Yeah just been on to Opie, and they said the Millers 75w/90 is too thick for the gearbox and recommended the Fuchs TITAN SINTOFLUID FE SAE 75W synthetic. Will have to change it as I'm worried about it when cold.
Is it difficult to do? May change mine cos why not!
Very easy, drain plug is underneath and fill plug on the front side of the gearbox. Both plugs need a 10 mm hexagonal bit to remove. Fill up to the point it starts coming out of the drain hole, approx 2.4 L
Dont you mean fill plug Rich
You need to clear the fault codes.
Do it ASAP as while airbag light is on, all your airbags are deactivated. So if you crash, they won't deploy....
Updated my Kenwood maps to the very latest![]()
Nope
2015.20
Though I almost bricked it uploading speed camera POIs. Wrong type of custom POIs.... For GARMIN only. Fixed it though![]()
