Petecog79
296
Just had car scanned came up with coolant pump open circuit . Been advised to change coolant temp sensor first. What does anyone think or has anyone had same error. Car drives perfect and heats up fine .
Where is the electric cooling pump located so I can check connection plug. My car is a cr 170 fr
The coolant pump is underneath just in front of the sump and beside the rigid intercooler to engine pipe.
Very common on 2009 cars.
What years yours?
If you check the number on the side of your original pump and Google it you'll buy a genuine delivered from Germany for about £90
A genuine from the dealers or Tps is about £140
2009! Is my car ok to drive then also is it worth changing the coolant temp sensor first or not. Fault reappeared second time I started it after fault was cleared.
Car is safe to drive and it's nothing to do with the temp sensor.
It's the after run coolant pump which circulates coolant when you turn the key off.
Depending on engine temp whether it's needed or not.
Ok short term but don't forget about it
Yeah thats the fault is it worth checking connection or just fit a new one and are they easy to fit im not bad with a spanner lol
It's worth a look at the connection but it'll be fine.
If you try to remove the whole bracket it's a pain
If you remove the 3 torx screws it's a 15 minute job.
Although 1 of the screws I gripped with vice grips to remove as there's no room to get a bit on it.
Once the undertrays off you'll see it's straight forward
Where exactly is the pump can it only be seen from underneath
Here is the replacement guide - 2009 Leon FR
Hope it helps
Is this the auxiliary electric pump that comes on once engine is off thats the one im after its giving me open circuit error
One thing will eml reset itself once new pump on or will it need resetting. Is this possible without diag tool
Just had undertray off and disconnected pump. When reconnecting I dont think it the plug was clipped in properly. Ive cleared fault and have started car 5 or 6 times in last 2 hours with no eml on .... yet ! Would this fault hsppen straight away or reappear in time
The fault will return next time the ecu wants to run the pump.
Usually after a long run when coolant temps high.
Wouldn't get excited as it will return.
The pump seizes in the housing.
I personally wouldn't waste money. I'd get the number from your original pump and source a genuine one and between parts and labour save yourself £150
Got number 5NO 965 561 finding it hard to source one seen plenty with A on the end of code but these look different
