Hi I have put 2 led interior lights in my ibiza and it's about as useful as a candle! I then went to my local car spares and brought a traditional bulb however when inserted doesn't light at all. Any ideas or solutions will beggreatly appreciated
Many thanks
Hmm okay, usually best to start simple; are they the correct bulbs?
If it's the two little map lights you're looking at then they should be 501 T10 W5W bulbs.
Failing that, if your other LED ones still light up in the holder then I'd be inclined to say the new bulbs are dodgy, though the chances of both the new ones being knackered is minimal.
Maybe someone with a bit more knowledge could figure this one out as the only suggestions I have are the ones above :/
Was the light working before you swapped to LED ? If not , the light may not be working. The new LED may glow slightly as it is getting a bit of voltage (hence you think its not bright) and the halogen one wont work at all as it needs the full 12 volts.
Okay thanks I'll put a volt metre on it however when the door is closed there very dim obviously because there is small current there and when the door is open it does go brighter just not as bright as I need also when I got the car they didn't have bulbs in them
Is there a method of fixing this as I have this problem on mine and if I unlock the car, open the driver's door it will re-lock itself automatically lock itslef as it hasn't detected a door opening.
