Does anybody know how to disable the automatic door locking system (when staring driving) via VCDS?
you don't need VCDS to do that, its just an option with the menu
Code:
Programming the Auto Lock (vehicles with Easy Connect)
Select: control button
Systems or Vehicle systems > Vehicle settings > Locking while driving
Auto Lock/Locking while driving
- If you select on, all the vehicle doors are locked at speeds above 15 km/h (10 mph).
Could some please post their coding from 5F and 09 and all their daytime running light and light adaptions.. Has to be a Leon With tech pack and led headlights please:)
May be able to pull something out this weekend if I don't get called to work, most lighting is done by adaptations and not long coding. An idea of what you are trying to achieve would be helpful.
Basically my daytime running lights are no longer running.. I was needing someone with the same spec car to copy they adaptions to sort the DRL's out:) any help like atm would be grateful as I don't own this wire I'm using:)
Hi Adaam,
If you need additional info here are the scans I did after taking delivery of the vehicle for the modules you're after.
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5F0 035 858 A HW: 5F0 035 858 A
Component: MU-S-ND-ER 040 0425
Serial number: E5F00512132119
Coding: 04730001FF0A000021111101000800002F0101060100010046
Shop #: WSC 00049 770 00129
ASAM Dataset: EV_MUStd6C3PASE 002029
ROD: EV_MUStd6C3PASE_SE37.rod
VCID: 29591B2648592F56E3D-807C
Media Player Position 1:
Subsystem 1 - Part No SW: 5F0 919 603 A HW: 5F0 919 603 A
Component: ABTmin_Std_Nv H51 0022
Serial number: SEZ8Z9NL400KQE
Engine Control Module 2:
Subsystem 2 - Part No SW: 5F0 919 866 F HW: -----------
Component: ECE 2014 --- 0036
Serial number: --------------------
No fault code found.
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011333401549
Coding: 0B000A46C24102FB0BA44000B11C07281000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7BF5116EF2456DC6C11-802E
Subsystem 1 - Part No SW: 5F2 955 119 HW: 5F1 955 119
Component: WWS370 131028 041 0574
Serial number: 131029220847
Coding: 0BC5FD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547
Component: RLFS 024 0042
Serial number: Y13M12D04H03M16S01S1
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY131960C4M
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000028471113
That should help can I ask what kind of car yours is like spec and that?
Mines is an SE with Tech Pack incl LED lights, with regard to lighting I enabled the following:
1. Cornering light with Fog Lights (will only work with headlights on either Manual or Auto)
2. Both Fog Light illuminate on reverse (again headlight need to be on)
Both these options seem to be removed for LED headlights, I've just enabled them.
Regards
Got my 13 plate Leon SE with tech pack a few weeks ago, and am keen to make some changes. The two main things would be to activate the rear DRLs and the passenger mirror reversing dip.
My local garage has VCDS and has agreed to try to implement these changes if I print out and bring the instruction guide with me.
Has anyone else managed to make these changes on the same model, or has anyone had any problems doing so?
Thanks in advance
Bought chinese copy of VCDS 12.12 and used "cracked" software. Everything seems to be working OK till connecting the cable to the car.
When the cable is connected and I run "test" module, then VCDS software changes from registered to unregistered/not authorized and therefore I am basically not able to do anything (even full scan)
Has somebody else had same problem? How to fix it?
Was wondering if it had auto updated. My suggestion would be completely uninstall and start again. What OS are you using?
nope, no auto update was done
tried win7, xp
i previously used original drivers, can this be a problem? after uninstalling the drivers win does not recognize cable correctly (in device manager it has ! mark and is listed under other devices)
Bought new chinese cable - works ok :)
Maybe a stupid question - but is it possible to apply original (or modified) coding after doing some changes? For example is it possible to import the auto-scan log file? if yes, then how?
There is no automated way to re-apply all the original codings in one go. You would need to copy each of the long coding values from the Auto-Scan you took before you made the changes and then manually paste them back into and apply them to each module, one at a time. You can also find a log of any changes you made in the "CodingLog.TXT" file under the "C:\Ross-Tech\VCDS\Debug" folder.
